Françoise
Dashboard window
hello,
I've a cript to make a dashboard 3x2.
When the script run, I would like to have the dashboard in a full screen , not in a small window.
How can I do it?
best regards
Re: Dashboard window
I generally find it easier to add the script from the GUI interface.  The scripts are usually hidden in Dashboard Mode, but you can switch to Application Builder using the option in the red-triangle menu:
Then you can switch to the "Scripts" tab for Module1 and enter the script there:
I've attached a sample Dashboard that demonstrates this.
It looks like your colleague has turned on the Report preferences for "Date Title on Output" and "Data Table Title on Output".  The latter option in this case is showing not only the data table name but also the additional text including the full SQL for the source of the table.  We will look into this further to see what improvements can be made, but I think the solution for now would be to turn this option off in Preferences.  I think the graphs are being stretched down to a size of 0 or possibly clipped, because the text is very large and is not stretchable.
16 REPLIES 16
uday_guntupalli
Level VIII
@Françoise
 While creating the dashboard or with an existing dashboard , if you choose to edit and click on the outer most window, you can adjust its size . Hopefully this helps
Best
Uday
uday_guntupalli
Level VIII
@Françoise
        If you already have a script , you can look for a Size function in the script and edit the arguments to change the window size
Best
Uday
Françoise
I don't know where it is inside my script.
Is there at the end of the script: like this?
where is it and wich value?
Best regards
uday_guntupalli
Level VIII
@Françoise
       Can you make this edit on line 739 and see if this edits the window size
Module1 << Set Min Size(2000,1000);
Best
Uday
Françoise
no change.
best regards
cwillden
Hi @Françoise,
Put this line in your script just after "thisModuleInstance << Create Objects;"
(thisModuleInstance << Get Box) << Maximize Window;
-- Cameron Willden
Françoise
no change with that:
cwillden
You really need to do it on a separate line and make sure you paste it exactly as written. The way you have it right now, you are sending the maximize window message to the module instance, and not the window containing the module instance. The << get box message is critical and so are the parentheses surrounding that code snippet.
-- Cameron Willden
Françoise
hello,
I've tried different ways.
no change.
best regards
