Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
Nitipp
Dashboard Builder using JMP Clinical 6
I am trying to generate  "risk-based monitoring" workflow using JMP Clinical 6. I would like to integrate RBM output into the dashboard for our clients to access the output, who do not have JMP installed.
1. Is there any online help available to build dashboard using JMP Clinical 6. The one on JMP.com is for JMPPro and lots of options has changed since then.
2. Is it possible to integrate RBM outputs on dashboard using JMP Clinical 6.
Thanks for your suggestions and help in advance.
sseligman
Re: Dashboard Builder using JMP Clinical 6
Unfortunately, Dashboard Builder was a new feature in JMP 13, and JMP Clinical 6 versions run with JMP 12.2. The next version of JMP Clinical, scheduled to be released in the fall, is planned to run with JMP version 14.1, and the Dashboard Builder functionality will be able to be used.
sseligman
Nitipp
Thanks Sarah.
Article Labels
