outlier
DOE effects Pareto
How can I get a Pareto of the magnitude of each effect from the DoE platform? I would like to see a Pareto of which effect is having most influence on the response parameter, including interactions.
For the popcorn example I can see table of effects with F and p values. I am guessing significant F values would be what I want..?
louv
Staff (Retired)
Re: DOE effects Pareto
Looking at the Popcorn example run the Model script from the data table. Then for Response=Number Popped if you pull down the red triangle there is an option to choose Effect Screening>Pareto Plot among other options.
Message was edited by: Lou V
outlier
Thanks.
