BookmarkSubscribeRSS Feed
shoffmeister
Mar 27, 2015
DOE Scripting: Get the power
Hi JMP-Gurus, again.
I'm playing around with DoEs in JSL. Now I was wondering how I could get the power for the factors? I tried
dsd = DOE(Definitive Screening);
dsd << Add Factor;
dsd << Add Factor;
dsd << Add Factor;
dsd << Add Factor;
dsd << Make Design;
dsd << Get Power;
But somehow the "Get Power"-functions seems to return a "DOE"-object instead of the vectors that I expected. At the same time the demo code from the scripting index works:
dt = Open(
  "$SAMPLE_DATA/Design Experiment/Bounce Data.jmp"
d = DOE(
  Evaluate Design,
  X( :Silica, :Sulfur, :Silane ),
  Y( :Stretch )
d << Get Power;
But I would prefer to get the power without having to set up the whole design and then creating a new DOE-Evaluation-object. This seems to be a bit inconvenient for me.
Thanks for any help,
Sebastian!
ryan_lekivetz
Nov 1, 2013
Solution
Re: DOE Scripting: Get the power
You're correct that it currently is only recognized by Evaluate Design - we'll look into getting that corrected in a future version. In the meantime, this should work with the jsl you provided above:
rpt = dsd << report;
rpt[OutlineBox("Power Analysis")][NumberColBox("Power")]<<getasmatrix;
ryan_lekivetz
Nov 1, 2013
Solution
shoffmeister
Mar 27, 2015
Thanks a lot. That does the job!
