Hi & Sorry for bothering you again.
Somehow I can't find a way to create a full-factorial design for a variable number of factors (k). Same for fractional factorial design. I know how to do it if I know the number of factors, as I can use
full_factorial_design = DOE(Screening Design);
full_factorial_design << add factor;
full_factorial_design << Make Design(4);
But this works only if i want to select the 4th design in the design list. This would not be the full-factorial design if I had 6 factors.
Is there any documentation about the scripting functions for the DOE-platforms in JMP? I could not find anything in the Scripting Guide or the DOE-pdf. Sadly the Scripting-Index isn't very helpful either.
Thanks for all hints!
Sebastian
If you want a full factorial design, you can use the Full Factorial designer:
DOE(
Full Factorial Design,
{Add Response( Maximize, "Y", ., ., . ),
Add Factor( Continuous, {-1, 1}, "X1", 0 ),
Add Factor( Continuous, {-1, 1}, "X2", 0 ),
Add Factor( Continuous, {-1, 1}, "X3", 0 ),
Add Factor( Continuous, {-1, 1}, "X4", 0 ),
Add Factor( Continuous, {-1, 1}, "X5", 0 ),
Make Design}
I don't see an obvious way to get the contents of the design choices from the Screening designer, so that you can see what each number design is.
-Jeff
Continuing the way that you started, you could iterate for the necessary number of factors.
n = 4;
For( f = 1, f <=n, f++, full_factorial_design << add factor);
full_factorial_design << Make Design(n);
Hi Mark,
thanks for the reply. Sadly this does not solve my problem as Make Design(4) will be a full-factorial design for 4 factors (as it is the 4th design in the design list) but Make Design(5) is not the full-factorial design for 5 factors.
DOE(
Make Design}
-Jeff
Thanks a lot! That does the trick for the full factorials.
Is there any documentation on the different designs? How would I do the same thing for fractional factorials, etc? How do I select a fractional design of a specific resolution? Usually I'm good at figuring this kind of stuff out on my own, but I couldn't find any documentation on that.
Kind regards,
Sebastian
