Ainaskid
DOE Output limit
Hi all,
Just curious. Is there a limit to the number of outputs/responses entered into a DOE?
Thanks,
Olu.
cwillden
Re: DOE Output limit
Not sure, but it doesn't impact the design generation at all.  The only thing specifying responses in the DOE dialog does for you is to set up the analysis for you once you populate those columns.  If there is a limit, it's probably a ridiculously large number.
-- Cameron Willden
cwillden
-- Cameron Willden
