TWE
TWE
DB query with prompt on run and listbox filter type based on char data type
I'm using JMP15 and I want to bild a db query with the "listbox" or "manual listbox"  as filter type and the "prompt on run" function for a column with character as data type.
JMP crashes everytime.
Interestingly "contains" as filter type works but does not make sense for my application.
Thanks for help.
jongtae
RE: DB query with prompt on run and listbox filter type based on char data type
I prefer to make SQL statements. And I create an application screen.
In the application screen, you can see that I create a condition like a filter with a Listbox.
jongtae
TWE
TWE
Thanks for the quick response. This could be work-around and works well!
Nevertheless it would be interesting why JMP crashes when using the query builder ...
