Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
Customized graph with random labels
I'm writing a script within a graphic for a customization example. I ran a regular fit model platform with some data and added the following to the actual vs. predicted plot:
//This adds the customized Boeing piece
Marker Size( 5 );
Marker( Color State( "Green" ), {762290, 762290} );
Text Size( 9 );
Text( Text Color( "Green" ), {802290, 652290}, "Program X - Boeing Offer" );
Pen Color( "Green" );
Line( {802290, 652290 + 35000}, {762290, 762290} );
//This adds the customized Supplier Piece
Marker Size( 5 );
Marker( Color State( "Red" ), {762290, 1147500} );
Text Size( 9 );
Text( Text Color( "Red" ), {292290, 1147500 + 35000}, "Program X - Supplier Offer" );
However, there are some latent labels which keep appearing and I can't figure out why. The script only touches the red and green sets of information. They look to be  located at the ends of the lines on the graph which is odd due to the script impacting a label created by JMP and that 0 value follows the "Program Y" label around when the line moves.
Am I missing some closeout type command for the lines or added labels?
Jeff_Perkinson
Re: Customized graph with random labels
Is it possible that you've got a row labeled in the data table?
-Jeff
-Jeff
Article Labels
