Customize in JSL
Hi JMP users,
Does anyone know how to shorten the amount of code it takes to capture changes when the Customize command is used? I am using JMP 9.0.0 and have a ONEWAY analysis with several box plots, I use the customize option to change box plots color from red to black. After making the edits to each box plot (about 22 of them) I capture the script and there are now 40 additional lines of code for the color. In JMP 8, there was about 2 lines of codes to do the same thing, but this code no longer functions in JMP 9.
Here is the portion of code from JMP 9:
Dispatch({},"Oneway Plot",FrameBox,{Frame Size( 850, 450 ), Marker Size( 1 ),
Marker Drawing Mode( "Normal" ), Transparency( 0.75 ),
DispatchSeg(CustomStreamSeg( 3 ),{Line Color( {255, 0, 0} ), Line Width( 2 )}),
DispatchSeg(CustomStreamSeg( 6 ),{Line Color( {255, 0, 0} ), Line Width( 2 )}),
DispatchSeg( MarkerSeg( 1 ), {Transparency( 0.75 )} ),
DispatchSeg(BoxPlotSeg( 1 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 2 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 3 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 4 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 5 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 6 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 7 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 8 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 9 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 10 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 11 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 12 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 13 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 14 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 15 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 16 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 17 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 18 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 19 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 20 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 21 ),{Box Style( "Outlier" ), Line Width( 2 )}),
DispatchSeg(BoxPlotSeg( 22 ),{Box Style( "Outlier" ), Line Width( 2 )}),
Row Legend(AREA,Color( 1 ),Color Theme( "Jet" ),Marker( 1 ),Marker Theme( "Standard" ),
Continuous Scale( 0 ),Reverse Scale( 0 ),Excluded Rows( 0 ) )}),
