TYP
TYP
Custom formula to normalize a data set by sub-set averages
I am looking to normalize a set of data with the Mean calculated with the following restrictions:
- Mean(Value) by Index
- Only those rows with Baseline=="Yes" are included in the mean calculations
- All rows with the same Index will be normalized by the Mean calculated above.
For example,
Index   Value   Baseline     Normalized value
1           2         Yes             2/Mean(2,3,3)
1           3         Yes             3/Mean(2,3,3)
1           2         No              2/Mean(2,3,3)
2           4         Yes             4/Mean(4,4)
2           4         Yes             4/Mean(4,4)
2           3         No              3/Mean(4,4)
2           4         No              4/Mean(4,4)
I tried the following but it does not put the correct Mean in the rows where Baseline != "Y"
Value/Col Mean( :Response, :Index, :Baseline  == "Y" )
Thanks in advance for any suggestions!
Re: Custom formula to normalize a data set by sub-set averages
Your formula is oh sooooooooo close.
Try
:Value / Col Mean( If( :Baseline == "Yes", :Value, . ), :Index )
Try
TYP
TYP
Thanks a lot @txnelson  for the solution! It works exactly how I needed it to.
Let me see if I understand the formula:
- If :Baseline is "Yes", then :Value is sent for Col Mean calculation, to be grouped by Index
- Else no value (.) is sent for Col Mean calculation.
correct
