BookmarkSubscribeRSS Feed
saitcopuroglu
Sep 29, 2014
Cum Sum By Variable1 Variable2 Variable3
I searched but I couldn't find a formula fro Cumulative Summary by Variables (variable1, variable2, variable3....) like let's say "ColSum" function.
I asked few times here at discussion board and thanks a lot the developers were very helpful, however the variables being char or num changes the final result. As a JMP user  I would be very happy if a CumSum by Variables function would be available under statistics group formula (just a suggestion).
May I ask which formulas should I write in column formula for:
CumSum for 3 variables (variable1, variable2, variable3) if all the variables are character?
CumSum for 3 variables (variable1, variable2, variable3) if all the variables are numeric?
CumSum for 3 variables (variable1, variable2, variable3) if some variables are character and some variables are numeric?
Many thanks in advance.
ms
Jun 23, 2011
Re: Cum Sum By Variable1 Variable2 Variable3
What was the method you used that depends on data type?
If you are looking for a column formula solution, try the Col Sum() function. It is very versatile.
Se below example of how to use ColSum() to give a cumulative sum with two by-variables. Doesn't matter whether the by-variables are character or numeric. The sum-variable must of course be continuous.
F = Expr(Eval(Eval Expr(Col Sum(:weight, Row() <= Expr(Row()), :sex, :age))));
dt << New Column("CumSum of weight by sex and age", numeric, formula(Name Expr(F)));
saitcopuroglu
Sep 29, 2014
Dear MS,
The solution is genius, thank you! It even accepts the missing values as null.
However it is an incredible "processor power hungry" formula. With a mid 2010 Mac creating a new formula column of 3600 wows by one variable took 20 mins. With a 124000 rows I went to sleep after 1 hour, and it was ready when I woke up...
markbailey
Jun 23, 2011
Your description is somewhat general, so I will offer general suggestions. Have your tried Tables > Summary? Have you tried Analyze > Tabulate? Have you tried Summarize() in a script?
saitcopuroglu
Sep 29, 2014
Dear MarkBailey,
None of them help me, the formula is need for adding new column to a table which is also a summary. Moreover I do not know if there is any kind of Summary/Tabulate which can replace a data with Cumulative Summary
