BookmarkSubscribeRSS Feed
geovany13
Community Member
Oct 16, 2013
Cubes in JMP
Hi !!
My question is, JMP works with cubes? I mean, I can create cubes with JMP?
for example, OLAP Cubes, Multidimensional cubes, etc. So as does SAS
Thanks for your answers
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: Cubes in JMP
JMP definitely can't create cubes for use outside of JMP.
Neither does JMP have the concept of a cube internally. Generally cubes represent data that has been summarized along various dimensions.
Given the raw, transaction-level data, JMP can do this kind of "slice-and-dice" summarization in real time, especially using the Tabulate platform and the data filter.
Can you give some examples of the kinds of things you'd like to do? Then we can give you some ideas about how to use JMP to get there.
-Jeff
-Jeff
