d_barnett
Crop Image and Insert Crop Into Data Table
I'm currently running a script that inserts a 1Mb image into a data table using the following simple script ( where :link to image is a network drive where the jpg is stored)
Formula( Open( :Link to Image, "jpg" ) ),
Due to the size of the image the data table is getting large ( I have ~1500 images) and have tried the crop function but cannot get the syntax correct
one of the various ways I have tried is the following ( and probably all combinations of this apart from the correct one!).
Formula( Open( :Link to Image, "jpg" ) ) << crop( Left( 190 ), top( 0 ), bottom( 1690 ), Right( 700 ) ),
I feel I'm close but not quite there.
Ideally it would do the following
  1. Open the image ( one at a time to save computer memory?)
  2. crop the image, then save the crop into a central folder. This would then allow for additional image analysis if required.
  3. Insert the crop into the data table
  4. Close the original image.
Regards
David
Re: Crop Image and Insert Crop Into Data Table
Here is an example script that does what you indicated you wanted
// Get the list of the pictures
filelist = Files In Directory( "$SAMPLE_IMAGES" );
// Loop across all of the pictures, cropping and saving
For( i = 1, i <= N Items( filelist ), i++,
       // Using a Substitute because the extension value needs to be an expression,
       // not a literal
       Eval(
              Substitute(
                           Expr(
                                  img = Open( "$SAMPLE_IMAGES\" || filelist[i], __extension__ )
                     Expr( __extension__ ), Parse( Word( -1, filelist[i], "." ) )
       // Allow time for the image to be read
       Wait( 1 );
       // Crop the image
       img << Crop( Left( 50 ), Right( 100 ), Top( 60 ), Bottom( 150 ) );
       // Save the image to a new folder
       img << Save Picture( "<path to save folder>" || filelist[i], Word( -1, filelist[i], "." ) );
// Create a new table
New Table( "Untitled",
  Add Rows( N Items( filelist ) ),
  New Column( "image", Expression, "None", Set Values( {} ) )
// Populate the image column
foreachrow(
  :image = newimage("<path to save folder>" || filelist[row()])
