abmayfield
Level V
Creating maps when crossing the dateline
I have a very unusual issue that is surely NOT to be very widely applicable: I am working with samples obtained very close to the international dateline (Fiji). When I go to overlay the data onto a map using pre-created shape files (one feature I love about JMP, BTW), it basically plots them on opposite sides of the globe, rather than center them around the 180 degree dateline. Upon a quick Googling, I noticed that this is an issue in other graphing software. I tried changing the access to geodesic, but this did not help. I tried to make a plot and place a background map of FIji behind it to see if this would do the trick, but it basically would not load the map! Any thoughts?
Anderson B. Mayfield
Craige_Hales
Staff (Retired)
Re: Creating maps when crossing the dateline
Add 360 to the negative longitude.
formula to add 360formula to add 360the image maps wrap but the outlines do not.
outline does not wrapoutline does not wrap
Craige
10 REPLIES 10
Craige_Hales
Staff (Retired)
Craige
abmayfield
Level V
Great! This seems to do the trick. I'll just need to manually change the y-axis (i.e., longitude) when I go to make the actual figure (i.e., convert 181 degrees back to -179). Thanks.
Jeff_Perkinson
Actually, I'm curious about the problem that you're seeing as it works for me if I've got the Geodesic axis scale on both X and Y.
Try the attached data table and the script in it and see what you get.
Here's my result.
-Jeff
abmayfield
Level V
Jeff,
Your data table plots correctly, but for some reason mine does not. Maybe I input something wrong? If you plot latitude versus longitude using in this table, they are plotted on opposite sides of the globe, even when set to geodesic!
Jeff_Perkinson
Sorry, I forgot to mention that you need to adjust the longitude (x) axis so that -180 is in the middle.
-Jeff
abmayfield
Level V
Now something is really going on with my graph: the longitude doesn't "wrap" at 180 but keeps going and going. Therefore, centering it at -180 degrees still gives a non-real presentation. It seems like changing the setting to "geodesic" should fix this?
Jeff_Perkinson
That's what you get if you only set the Longitude (X) axis to Geodesic.
You need to set Latitude (Y) to Geodesic also.
-Jeff
abmayfield
Level V
If I set both to axes geodesic, I get the attached image. I also tried geodesic US, but the outcome was the same. In any event, it's not hard to add 360 to the negative values, so I think I can just do that.
Jeff_Perkinson
Yes, that's correct. Notice that the Latitude axis is going from -163 to 125. Adjust it to zoom in to the range of your actual data. I add a background map below just to make it clearer whats going on.
-Jeff
