BookmarkSubscribeRSS Feed
waltp
Community Trekker
Creating an Overlay Plot based on a Radio Box Selection
I'm creating a script that creates an Overlay Plot with one variable (price) on the x-axis and two variables on the y-axis.  My script works fine, but now I want to create a dialog box in which a user could select which two variables to plot on the y-axis.  There are set combinations, so I would like to use a Radio Box with the acceptable pairs listed.  But unfortunately I can't tell the Overlay command which variables to use.  The relevant portion of my code is:
    Outline Box("Select Curves to Analyze",rb = Radio Box(
{"Optimal Price Point",
       "Indifference Price Point",
       "Point of Marginal Cheapness",
       "Point of Marginal Expensiveness"
   Outline Box("van Westendorf Graph",
   op = Data Table( "vw3" ) << Overlay Plot(
   X( :Price ),
   choose( rb << Get(),  Y( :Expensive, :Bargain ), Y( :Too Expensive, :Cheap ) ),
I though I'd use the choose function to return the relevant Y statement.  But this doesn't work.  Any suggestions?
Thanks,
Walt
pmroz
Re: Creating an Overlay Plot based on a Radio Box Selection
Walt,
This should fix up the initial part of your code:
choice_list = {"Optimal Price Point",
nw = new window("Select Curves to Analyze", << modal,
      rb = Radio Box(choice_list, option = rb << get;)
yaxis_label = choice_list[option];
waltp
Community Trekker
Thanks, but how do I still tell Overlay Plot which pair of variables (as in Y( :Expensive, :Bargain )  ) to use?
Walt
pmroz
Unfortunately you will have to resort to building a string dynamically that contains the commands to create your overlay plot, and then executing that string.  Here's an example that uses evalinsert:
dt = open("$sample_data\Car Physical Data.jmp");
choice_list = {"Turning Circle, Displacement", "Horsepower, Gas Tank Size"};
col_list    = {":Turning Circle, :Displacement", ":Horsepower, :Gas Tank Size"};
option = 1;
yaxis_cols  = col_list[option];
overlay_expr = evalinsert("\[Overlay Plot(
      X( :Weight ),
      Y( ^yaxis_cols^ ),
            Dispatch( {}, "", AxisBox, {Add Axis Label( "^yaxis_label^" )} ),
            Dispatch( {}, "Y", TextEditBox, {Set Text( "^yaxis_label^" )} )
eval(parse(overlay_expr));
It may seem complicated but I do this all the time when JMP doesn't want to recognize variables.
waltp
Community Trekker
Thanks for this suggestion.  It looks like it will do the trick, so I'll try it soon.
Thanks for all the help.
Walt
