sasuser1000
Community Member
Creating a decay variable
I am looking to create a variable that will have a different value by time based on another, in this case to create Y.
For example:
time   x     y
1       10    10
2        0      5
3        0      2.5
tomkari
Re: Creating a decay variable
You'll need to post a little more logic than that. As an example, from your post I might infer this:
For every record:
Copy X to Y
Output a result record
Until Y < .001
  X = 0
  Y = Y / 2
End
ms
Super User ms
You could use a column formula Y=10/(2^(Time-1)).
A table based on your example:
New Table( "untitled",
  Add Rows( 4 ),
  New Column( "Time",
  Numeric,
  Set Values( [1, 2, 3,] )
  New Column( "X",
  Numeric,
  Set Values( [10, 0, 0] )
  New Column( "Y",
  Numeric,
  Formula( :X[1] / 2 ^ (:Time - 1) )
