jstewart
Creating a column
I am a JMP novice and need some help.  I have a large database that tracks hospitalized patients over a 20 year period.  If a patient has a "*" in column "365 Mortality", I would like to put a 1 in column "Death" for every time that patient is listed.  See below.
Patient
365 MortalityDeath
1
1
1*1
2
2
2
3
1
3
1
3*1
4
4
5
1
5*1
mpb
Super User mpb
Re: Creating a column
And another approach:
dtmort = Data Table( "Mortality" );
dtby = dtmort << Summary(      Group( :Name( "365 Mortality" ), :Patient ),      Link to original data table( 0 ) );
dtby << select where( :name( "365 Mortality" ) != "*" );
dtby << delete rows;
dtby << New Column( "Death1", Numeric, Continuous, Format( "Best", 9 ), set each value( 1 ) );
dtby << delete columns( "365 Mortality" );
dtmort << Update( With( Data Table( dtby ) ),   Match Columns( :Patient = :Patient ),   Add Columns from Update table( :Death1 ) );
close( dtby, nosave);
jsurette
Creating a column
This can be done with an if statement, either through the column info pane or JSL.  Here is quick example of the JSL
dt = current data table();
dt << New Column( "Death", Formula( If(:Name("365 Mortality") == "*", 1) ));
pmroz
Creating a column
I think it's a little trickier than that.  jstewart wants a 1 in the Death column if any patient row has a *.  Here's one way to do it:
dt = data table("Mortality");
dt << New Column( "Death1", Numeric, Continuous, Format( "Best", 9 ));
dt1 = (dtab = dt << Tabulate(
      Show Control Panel( 0 ),
      Add Table( Row Table( Grouping Columns( :Patient, :Name( "365 Mortality" ) ) ) )
)) << Make Into Data Table;
dtab << close window;
for (i = 1, i <= nrows(dt1), i++,
      patient_no = column(dt1, "Patient")[i];
      pat_rows = dt << get rows where(:Patient == eval(patient_no));
      column(dt, "Death1")[pat_rows] = 1;
ms
Super User ms
Creating a column
Here's another way to do it. The approach can be applied to a column formula (run this script or paste the code inside Formula( ) into a new columns formula property):
dt << New Column( "death",
          formula( If( Associative Array( As List( :Patient << get values ), :Name( "365 Mortality" ) << get values )[:Patient[]] == "*", 1 ) )
Or alternatively, If there is no need for a dynamic formula or if the database is very large (complex formulas may slow things down), it can be done by a jsl script:
dt << Current Data Table();
col = (dt << New Column( "death" ));
For Each Row(
          If( Associative Array( As List( :Patient << get values ), Column( "365 Mortality" ) << get values )[:Patient[]] == "*",
                    col[] = 1
mpb
Super User mpb
jstewart
Creating a column
Thanks for all of your help!
