Bill_Even
Creating a Handle for a Graph Builder Window created from an Expression
I can easily create a handle for a Graph Builder window so that I can create the report layer:
myGraph = dt << Graph Builder(yada, yada, yada);
myRep = myGraph << Report;
Let's say that I want to modify an argument in Graph Builder before creating the graph:
myExpr = expr(Graph Builder(yada, yada, yada);
// Use remove from and insert into to modify myExpr
myExpr1 = expr(myGraph = dtIn << expr(myExpr));
eval expr(myExpr1);
When I use the above commands, the graph gets created, but it does not appear that myGraph is a proper handle, so I can't create a report layer with
How would I manipulate myExpr to create a handle when the graph is created?
I have a hack work around whuch I reallly don't like:
myList = window() << get window title;
// search myList for the number of items that contain the "Graph Builder" string (call this n)
myRep = Graph Builder[n] << Report;
Thanks,
Bill
Re: Creating a Handle for a Graph Builder Window created from an Expression
Here is an example that might be adapted to your purpose. It follows your original pattern of launching Graph Builder and then getting the reference to the report layer.
Names Default to Here( 1 );
gb expr = Expr(
	gb = dt << Graph Builder(
		Size( 534, 452 ),
		Show Control Panel( 0 ),
		Show Legend( 0 ),
		Variables( X( xxx ), Y( yyy ) ),
		Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
Eval(
	Substitute(
		Name Expr( gb expr ),
		Expr( yyy ), Expr( dt:weight ),
		Expr( xxx ), Expr( dt:height )
gb rep = gb << Report;
gb expr = Expr(
		Size( 534, 452 ),
		Show Legend( 0 ),
Eval(
	Substitute(
Bill_Even
Thank you very much Mark!!
Your explanation showed me how to do the substitution and evaluation in a single step.
Regards,
Bill
