BookmarkSubscribeRSS Feed
Creating HTML files from a JMP graphic output using JSL
I want to format my script so that the graphic output is automatically saved as .html. My script looks like this:
Open( "\\folder\filename.sas7bdat" ) << Tree Map(
Categories( :ID ),
Coloring( :ONE_MTH_CHNG ),
Sizes( :WEIGHT ),
Ordering( :ONE_MTH_CHNG ),
Anyone have any tips for doing this?
Thanks!
XanGregg
Jun 23, 2011
Re: Creating HTML files from a JMP graphic output using JSL
There's a Save HTML command for display elements. Example:
Thanks so much! That totally worked
