Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
Creating Contour Map To Highlight River Systems
Hi all,
I am looking to constrain my contour map attached within this discussion post to only the river system within the map for the parameter controlling color. I understand that adjusting the alpha may constrain the area, but it does not accurately reflect the river system. An example of what I want to accomplish is attached within this email.
Do I have to create a custom map as per (https://www.jmp.com/support/help/ipad/Create_a_Custom_Map.shtml) or is there another way that I can outline the river systems I am interested in? For instance can I add more points along the river to help for the alpha?
Let me know if you need anymore details.
Staff (Retired)
Re: Creating Contour Map To Highlight River Systems
You should probably make your own clip shape. Probably with some hard coded lat/lon values in a path.
tell a segment in a graph to clip to a regiontell a segment in a graph to clip to a region
dt=open("$sample_data/cities.jmp");
dt<<Graph Builder(
	Size( 1401, 943 ),
	Variables( X( :Longitude ), Y( :Latitude ) ),
	Elements( Points( X, Y, Legend( 3 ) ) ),
		Dispatch(
			"Longitude",
			ScaleBox,
			{Format( "Longitude DMM", "PUNDIR", 16, 1 ), Min( -79.2168192501673 ),
			Max( -77.9895685253635 ), Inc( 0.2 ), Minor Ticks( 0 )}
		Dispatch(
			"Latitude",
			ScaleBox,
			{Format( "Latitude DMM", "PUNDIR", 16, 2 ), Min( 35.357738544198 ),
			Max( 36.1836060907719 ), Inc( 0.05 ), Minor Ticks( 0 )}
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Background Map(
				Images( "Street Map Service" ),
				Boundaries( "US Counties" )
			), Grid Line Order( 3 ), Reference Line Order( 4 ),
			DispatchSeg(
				MapSeg( 1 )
				//,{Clip Shape( Boundaries( "US Counties", ID( "Wake County, NC" ) ) )}
				,{Clip Shape( Path("
				M -78.95 36.05
				L -79.13 35.89
				L -78.47 35.71 Z") ) }
The clip shape can be applied to any segment. Use right-click->Customize to figure out which segments you want. Above I made a triangle clip around three cities in NC. The path string is easier to read than the matrix.
TriangleTriangle
Article Labels
