BookmarkSubscribeRSS Feed
j_bonnouvrier
Dec 19, 2012
Creating Blob object
My problem is very simple but I am stuck with it: I Have a column called "Code". Let's say it is full of "3".
This column is the result of the reading of a memory encoded with 8-bit binary.
In my exemple, 3 is actually 00000011.
I would like to  convert 3 into 00000011. I tried the script:
New Column( "NEW_COLUMN", Numeric, Continuous );
Column( "NEW_COLUMN" ) <<Set Formula(Char To Blob(Char(:SERIAL_OTPB),"utf-8"));
But it fails. Any idea how to handle it?
Thanks in advance!
Jérôme
Jun 22, 2012
Re: Creating Blob object
Hi Jérôme,
If you use the following formula, it will create the character string you want
base = Function( {n},
{default local},
If( n != 0,
ndash = "";
digits = "0123456789ABCDEF";
While( n > 0,
remainder = Mod( n, 2 );
newdigit = Substr( digits, (1 + remainder), 1 );
ndash = newdigit || ndash;
n = (n - remainder) / 2;
ndash = Substr( "00000000", 1, 8 - Length( ndash ) ) || ndash;
Ndash = "00000000"
);base(:Code)
Assuming the target column is called "Code"
