Create new columns by loop formula calculation with specific column names
Hello dear jmp experts/users,
I have a fixed format data table with similar column name formats like this (always similar two column name distinguished by _1):
NAME, C1, P2 ... C1_1, P2_1 .... (actually many columns with this naming rule)
I'd like to create new columns with below formula: for exampe,
C1_cal by : C1-C1_1
P2_cal by : P2-P2_1
how do i use JSL to achieve loop for this? Thanks a lot!
Re: Create new columns by loop formula calculation with specific column names
Quite a lot of assumptions made regarding column names and column ordering
dt = New Table("Untitled",
	Add Rows(1),
	Compress File When Saved(1),
	New Column("Name", Character, "Nominal", Set Values({})),
	New Column("Column1", Numeric, "Continuous", Format("Best", 12), Set Values([1])),
	New Column("Column2", Numeric, "Continuous", Format("Best", 12), Set Values([2])),
	New Column("Column1_1", Numeric, "Continuous", Format("Best", 12), Set Values([2])),
	New Column("Column2_1", Numeric, "Continuous", Format("Best", 12), Set Values([4]))
all_colnames = dt << Get Column Names("String");
Remove From(all_colnames, 1); // Drop first column
For Each({col_name}, all_colnames[1::(N Items(all_colnames)/2)],
	Eval(Substitute(
		Expr(
			dt << New Column(col_name|| "_cal", Numeric, Continuous, Formula(
				_firstcol_ - _secondcol_
		Expr(_firstcol_), Name Expr(AsColumn(col_name)),
		Expr(_secondcol_), Name Expr(AsColumn(col_name || "_1"))
Scripting Index and Scripting Guide have good information regarding JMP Scripting. Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute is good post regarding how to build formulas from variables
Just try it and check the results and formula column property
	Add Rows(1),
	Eval(Substitute(
		Expr(
Thanks a lot!!!
if I'd like to change formular to  C1-3.5*C1_1:
should i change the code to below format?
_firstcol_ - 3.5*(_secondcol_)
