KfirDarina
Community Trekker
Create local variables that hold lists from column names
Hi all,
Need your help with creating multiple local variables that contain column names within var name.
I'v tried this butget an err.
Any suggestions?
for(j=1,j<=ncol(dt),j++,
local(parse(char(column name(j))||"key")=Associative Array(column(j)<<Get Values)<<get keys));
ian_jmp
Re: Create local variables that hold lists from column names
OK. Here's one way, and I'm sure there will be others:
varList = {};
For( j = 1, j <= N Col( dt ), j++,
	varName = (Column(dt, j ) << getName)||"_keys";
	keys = Associative Array( Column(dt, j ) << Get Values ) << get keys;
	makeVar = Expr(LHS = RHS);
	SubstituteInto(makeVar, Expr(LHS), Parse(varName), Expr(RHS), Eval(keys));
	makeVar;
	InsertInto(varList, Parse(varName));
Print(varList);
Print(EvalList(varList));
ian_jmp
Not sure I understand your use of 'Local()', but is this close to what you want?
keyVarList = {};
	keys = Associative Array( Column( j ) << Get Values ) << get keys;
	InsertInto(keyVarList, EvalList(List(keys)));
for(j = 1, j <= NItems(keyVarList), j++,
	Print(keyVarList[j]);
KfirDarina
Community Trekker
ian thx,
My intention is that for each list that was created by associative aray function it will also have a unique variable name that contain the matched column name.
For example: if I have two columns: Entity and Lot, then I will get two local variables :
Entitykey={entity1, entity2}
Lotkey={Lot1,Lot2}....
And so on for all columns in table
ian_jmp
varList = {};
	makeVar;
Print(varList);
KfirDarina
Community Trekker
ian thx. this is great, i was battling for 2 days to solve it, appreciate that :)
