Create graph from scratch in JMP
HI All,
i am pretty new to JMP. i want to create custom graph. e.g. i want to add main graph box, then add legend box horizontally,  etc.
thanks in advance.
michaelhaslam_p
Re: Create graph from scratch in JMP
Ram,
You need to supply some more detail with this question.  What type of graph?  What does the data look like?  Are you using menu drive JMP or scripting via the JMP scripting language (JSL)?
Michael
Hi Michael,
I am Using JSL. see the code below i am using to create XY plot.
1. Now i want to change the legends which appears right vertically to Top of the graph and horizontally.
2. i want to add add some kind of (say median of column summarized by legends
dt = Open("$SAMPLE_DATA/Pogo Jumps.JMP");
biv=Bivariate( Y( :Total ), X( :Yat ));
report(biv)[frame box(1)]<<frame size(400,300);
report(biv)[Framebox(1)]<<Row Legend( Finalist,
  Color( 1 ), Title Position ("Top"),
  Color Theme( "JMP Dark" ),Marker( 0 ), Marker Theme( "" ),
  Continuous Scale( 0 ),Reverse Scale( 0 ),Excluded Rows( 0 )
orthogonal
From the JMP Home Window go to Graph > Graph Builder.  Then drag and drop your data.
Article Labels
