Sburel
Create and populates new columns based categories in an existing column
I'm trying to build a quick query in which a categorical column (test_article) is used to  create a series of column which contains only a subset of the information. If the script works as intended, the table would end up with 2 new columns (PBS vs ...).
test_articlemeasurementPBS vs 709547PBS vs 709139
PBS1.23PBSPBS
PBS1.456PBSPBS
7095474.56709547EXCLUDE
709139
5.02EXCLUDE709139
7091396.02EXCLUDE709139
7095474.57709547EXCLUDE
I've tried the following script:
NamesDefaultToHere(1);
dt=current data table();
row = Associative Array( :test_article ) << Get Keys;
nc=N items (row);
For( i = 1, i <= nc, i++,
		new column("PBS vs "|| row[i],"Character", "Nominal", Formula(If( :test_article == "PBS", :test_article,
	If( :test_article == row[i],
		"test",
		"EXCLUDE"
Somehow, it does not populate any values in the new columns with the exception of 'PBS'.
Any suggestions?
Thanks a lot
Sebastien
Re: Create and populates new columns based categories in an existing column
The primary issue you are having is that within the definition of a formula, one can not have items that need to be evaluated.  JMP thinks everything within the formula definition is to be evaluated only when the formula is executed.
Therefore, the formula that is passed into the New Column definition, must be complete in it's syntax.  The modification of your code below works with your sample data table.
nc = N Items( row );
	Eval(
		Parse(
			"New Column( \!"PBS vs " || row[i] ||
		Character,
		Nominal,
		Formula(
		if (Row() == 1, theTest = \!""
			 || row[i] ||
			If( :test_article == \!"PBS\!",
				zip=:test_article,
				If( :test_article == theTest,
					zip=\!"test\!",
					zip=\!"EXCLUDE\!"
			zip
Jeff_Perkinson
You need to get the value of row[i] into the formula. JMP doesn't evaluate expressions inside the Formula() part of the New Column() message.
You can use Substitute() to get the actual value of row[i] into the formula.
	Eval(
		Substitute(
				Expr(
					New Column( "PBS vs " || row[i],
						"Character",
						"Nominal",
						Formula( If( :test_article == "PBS" | :test_article == ri, :test_article, "EXCLUDE" ) )
			Expr( ri ), Eval( row[i] )
-Jeff
	Eval(
		Parse(
		Character,
		Nominal,
		Formula(
			 || row[i] ||
				zip=:test_article,
					zip=\!"test\!",
					zip=\!"EXCLUDE\!"
			zip
Sburel
Works like a charm!
Thanks
Jeff_Perkinson
	Eval(
		Substitute(
				Expr(
						"Character",
						"Nominal",
-Jeff
Sburel
Also works like a charm.
Thanks a lot
