BookmarkSubscribeRSS Feed
jorgeramosdealm
Feb 20, 2012
Create a window with all variables
I would like to create a window with all the variables that are in use. I know that I can run
show symbols();
to show all the variables in use. However, this outputs to the log. I would like to get the output text and then use
caption(show symbols());
However, this syntax does not work. If someone could help me with this syntax it would be great. Thanks.
ms
Jun 23, 2011
Solution
Re: Create a window with all variables
Try Log Capture():
Caption( Log Capture( Show Symbols() ) );
ms
Jun 23, 2011
Solution
Try Log Capture():
jorgeramosdealm
Feb 20, 2012
Thanks MS. That was great. Deeply appreciated.
