ckaylor
Create a new column from others
I have a set of continuous measures (x1, x2, x3, x4) that are all measured on the same scale. I'd like to create a new nominal variable that identifies for each respondent which of the continuous measures is the maximum (whether x1, x2, etc).
ms
Super User ms
Re: Create a new column from others
One way is to use a column formula including Loc Max() function to identify the column with maximum value.
Example:
// Make example table
dt = New Table("test", add rows(25), <<add multiple columns("x", 4, Numeric));
For(i = 1, i <= N Col(dt), i++,
    Column(i) << Set Formula(Random Integer(10))
// Identify the column with highest value for each row
dt << New Column("max x", Character, Formula("x" || Char(Loc Max(Matrix({x1, x2, x3, x4})))));
Jeff_Perkinson
The If Max()function can take care of this for you in one call.
-Jeff
Jeff_Perkinson
BTW: If you're not sure how to get to the Formula Editor to create a formula like this, choose Cols->New Column... ​and then choose Formula from the Column Properties drop down menu.
-Jeff
