Sburel
Create a column formula using a column name from a list
I have a simple script where I want to create a new column in which a formula calculate the absolute value of another column.
 the column is referenced in a list.
I tried a few different ways, but I can't figure out how to evaluate the referenced column so I end up with an empty formula column. Any suggestion would be greatly appreciated.
Best
Sebastien
dt=New Table( "test",
	Add Rows( 4 ),
	New Column( "symbol",
		Character,
		"Nominal",
		Set Values( {"a", "b", "c", "d"} ),
		Set Display Width( 55 )
	New Column( "fold change",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [-3, -0.4, 0.4, 3] ),
		Set Display Width( 68 )
l={"fold change"};
try(New Column( "absolute fold change",
	Numeric,
	"Continuous",
	Formula( Abs( l[1] )
try(New Column( "absolute fold change 2",
	Numeric,
	"Continuous",
	Formula( eval(column(l[1]) )
lgober
Re: Create a column formula using a column name from a list
	Add Rows( 4 ),
		Character,
		"Nominal",
		Numeric,
		"Continuous",
l = {"fold change"};
	Numeric,
	"Continuous",
	Formula( Abs( column( l[1] )[] )
Since your list contains only strings, you need to tell JMP that the string is a column name by using the Column( "" )[ ] function.
The blank square brackets are necessary as well as without them, the formula will reference the entire column instead of only the appropriate row.
Hope this helped,
Lain
lgober
No problem. I had this exact same issue yesterday and it took me a while to figure it out.
I actually just learned of another solution to this, too.
The 'As Column()' function will return the value of the current row in the column specified as an argument.
So that formula could equally have been formatted like this:
Formula(
Abs( As Column( l[1] ) );
Pretty neat!
lgober
	Add Rows( 4 ),
		Character,
		"Nominal",
		Numeric,
		"Continuous",
	Numeric,
	"Continuous",
Hope this helped,
Lain
Sburel
Thanks a lot, I had tried the option you proposed with one big difference: No empty brackets.
Best,
Sebastien
lgober
Formula(
Pretty neat!
