sagrim
Create Categorical Variable Using Two Timepoints
If anyone can help with this I would greatly appreciate it !
I am trying to create a categorical variable that will reflect changes in employment based on two variables: JOBCODE TimePoint 2 and JOBCODE TimePoint 2.
In essence, this categorical variable will allow me to see whether any given employee has one of the following events from timepoint 1 to timepoint 2: joined the organization (new employee), changed JOBCODE (transferred within the organization), or left the organization (termination/separation).
The code below represents my data structure is because any new employees will have a blank/ null value for their JOBCODE at Timepoint 1, any terminated employees will have a blank/ null value for JOBCODE at Timepoint 2 and any employees who changed positions will have a non-match JOBCODE in the field from Timepoint 1 to Timepoint 2.
As far as the command for blank/null goes, I have tried a number of different things.  I tried using isMissing as well as == “” and I have also tried !contains.  None of them work.  I don’t have a preference on which one of these styles is used as long as it works.
For those employees who transfer, I am only interested in whether or not they kept a job code contained in mylist
I created a mock data table.  Column 1 is some made up employee IDs for the sake of example.  Column 2 and 3 represent jobcodes at Timepoint 1 and Timepoint 2.  Column 4 is the output I would expect based on the values I entered in Column 2 & 3.  Column 5 is some notes for clarification.
new column ("JOBCODE Status", Character, Nominal) << Formula
(If (Contains (mylist, :"JOBCODE Timepoint1") & !Contains (mylist, :"JOBCODE Timepoint2"),"Change in JOBCODE",
(If (Contains (mylist, :"JOBCODE Timepoint1") & Contains (mylist, :"JOBCODE Timepoint2"),"No Change",
(If (Contains (mylist, :"JOBCODE Timepoint1") & isMissing (:"JOBCODE Timepoint2"),
"Termination/Separation",
(If (isMissing (mylist, :"JOBCODE Timepoint1") & Contains (:"JOBCODE Timepoint2"),
"New Employee",
mylist= {"HH0029",
"HH0030",
"HH0241",
"HH0242",
"HH0317",
"HH0635",
"HH0635",
"HH0636",
"HH0636",
"HH0639",
"HH0742",
"HH0750",
"HX0002",
"HX0003",
"HX0008",
"HX0010",
"HX0022",
"HX0106",
"HX0106",
"HX0107",
"HX0114",
"HX0115",
"SH0049",
"SH0504",
"SH0678",
"HH0113",
"HH0708",
"HH0746",
"HX0111",
"NU0017",
"NU0100",
"NU0200",
"NU0203",
"NU0206",
"NU0207",
"NU0213",
"NU0243",
"NU0244",
"NU0300",
"NU0301",
"NU0305",
"NU0327",
"NU0328",
"NU0362",
"NU0364",
"NU0400",
"NU0422",
"NU0423",
"NU0424",
"NU0425",
"NU0440",
"NU0461",
"NU0615",
"NU0618",
"NU0619",
"NU0620",
"NU0621",
"NU0622",
"NU0625",
"NU0800",
"NU0801",
"NU0923",
"NX0002",
"NX0006",
"NX0017",
"NX0018",
"NX0019",
"NX0023",
"NX0125",
"NX0465",
"NX0466",
"NX0609",
"NX0610",
"NU0610",
"NU0700",
"NU0710",
"NU0713",
"NU0922",
"NU0364",
"NX0609",
"NX0610"};
Re: Create Categorical Variable Using Two Timepoints
Here is my rework of your code that seems to work
New Column( "myJOBCODE Status", Character, Nominal ) << Formula(
	If( Row() == 1,
		mylist = {"HH0029", "HH0030", "HH0241", "HH0242", "HH0317", "HH0635", "HH0635", "HH0636", "HH0636", "HH0639", "HH0742",
		"HH0750", "HX0002", "HX0003", "HX0008", "HX0010", "HX0022", "HX0106", "HX0106", "HX0107", "HX0114", "HX0115", "SH0049",
		"SH0504", "SH0678", "HH0113", "HH0708", "HH0746", "HX0111", "NU0017", "NU0100", "NU0200", "NU0203", "NU0206", "NU0207",
		"NU0213", "NU0243", "NU0244", "NU0300", "NU0301", "NU0305", "NU0327", "NU0328", "NU0362", "NU0364", "NU0400", "NU0422",
		"NU0423", "NU0424", "NU0425", "NU0440", "NU0461", "NU0615", "NU0618", "NU0619", "NU0620", "NU0621", "NU0622", "NU0625",
		"NU0800", "NU0801", "NU0923", "NX0002", "NX0006", "NX0017", "NX0018", "NX0019", "NX0023", "NX0125", "NX0465", "NX0466",
		"NX0609", "NX0610", "NU0610", "NU0700", "NU0710", "NU0713", "NU0922", "NU0364", "NX0609", "NX0610"}
	isThere = Function( {value},
		If( Contains( mylist, value ),
			1,
			0
	a = :JOBCODE Timepoint1;
	b = :JOBCODE Timepoint2;
	If(
		isThere( a ) & b == "", "Termination/Separation",
		a == "" & isThere( b ), "New Employee",
		isThere( a ) & isThere( b ), "No Change"
	If( Row() == 1,
			1,
			0
	If(
sagrim
I can't thank you enough for your help ! Not only does your code accomplish what I intended but your version is also much more efficient than mine. Nicely done sir !
