BookmarkSubscribeRSS Feed
kyle_lamson
Mar 17, 2016
Counting a subset of column values
I'm trying to count a subset of values using another column as the marker. For any number of samples that have multiple subsets, how can I count the states of those subsets?
For example:
Samplesubsetfailureyield
1a
yes
50%
1ano50%
1bno100%
2ayes100%
2ayes100%
2bno0%
Samples have subsets "a" and "b", that fail or pass. I'm trying to find the yield of those subsets. I'm sure there's some combination of lag, diff, col number, that I can use but I can't get it. Any help or functions that I could possibly use would be greatly appreciated.
Thanks
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: Counting a subset of column values
Is there some reason you need this in a column in the original data table?
You can get this from Tabulate. Here I'm using the Row % statistic to compute the value you're looking for. I saved the script to the data table made from your table above and attached it here so you can see how it's done.
-Jeff
-Jeff
kyle_lamson
Mar 17, 2016
I'm making a quick and dirty reporting window with a column switcher and it'd be nice to have yield v time on it.
brady_brady
Jun 9, 2012
Kyle, you can use this cumbersome column formula, assuming the yield in line 3 of your example was meant to be 0, (otherwise, the results in rows 3 and 6 of your example seem at odds.)
