BookmarkSubscribeRSS Feed
Re: Could any expert check on my jsl script?
bernie426
Community Trekker
Feb 9, 2015
I tried to wrote a simple jsl script to pull data from a SQL database with a functionality to select pulling data from a set time frame. However, after checking from couple times I still cannot find out the mistake. The script debugger saying -[Microsoft][ODBC SQL Server Driver][SQL Server]Unclosed quotation mark after the character string ''.
Could any one help me to check out where is wrong in my script?
//This script is wrote to pull data within a certain time frame
start_time_="02/23/2015 12:00:00 AM";
end_time_="02/24/2015 12:00:00 PM";
Open Database(  "DSN=;Description=;UID=;PWD=;APP=JMP;WSID=;DATABASE=",
  "SELECT * FROM dbo.WORKWEEK
  WHERE ((dCreated >= '",start_time,"')
  AND (dCreated <='",end_time,"'))
  ORDER BY dCreated",
  "Updated Table"
dCreated is the column from the database that used to provide time information. It is a numeric data type, continuous modeling type and the format is already set to m/d/y/ h:m:s
Many Thanks,
Mar 21, 2013
Solution
  WHERE ((dCreated >=  ' " || start_time_ || " ' )
  AND (dCreated <= ' " || end_time_ || " ' ))
  ORDER BY dCreated "
  WHERE ((dCreated >=  ' 02/23/2015 12:00:00 AM ' )
  AND (dCreated <= ' 02/24/2015 12:00:00 PM ' ))
  ORDER BY dCreated "
use || for the string concatenation in JSL.  I added the space between the apostrophe and the quotation mark just so I could see them better, you'll need to remove it most likely.
Mar 21, 2013
Solution
  ORDER BY dCreated "
  ORDER BY dCreated "
bernie426
Community Trekker
Feb 9, 2015
Thanks a lot Craige
pmroz
Jun 23, 2011
I use EVALINSERT for a cleaner look to the sql statement.  To use it, enclose any variables you want evaluated in ^ characters.
start_time_ = "02/23/2015 12:00:00 AM";
end_time_   = "02/24/2015 12:00:00 PM";
sql_statement = evalinsert(
  WHERE dCreated >= '^start_time_^'
    AND dCreated <= '^end_time_^'
  ORDER BY dCreated");
Open Database(
    sql_statement,
    "Updated Table"
bernie426
Community Trekker
Feb 9, 2015
Hi PMroz,
Does the EVALINSERT having the same functionality/meaning as "||?
Does it means ^ equal "||?
Thanks,
Mar 21, 2013
Lists and Expressions is part of the online help for JSL; there is also a built-in set of examples in Help->Scripting Index, although this particular example isn't very detailed.  Help->Books->Scripting Guide is the pdf book on your computer and has a better example.
I'd say the two techniques are complementary, and in this particular case EvalInsert might make your JSL easier to understand.  They accomplish the same thing, in very different ways.
pmroz
Jun 23, 2011
C Hales is correct - the two techniques are complementary.  You can use evalinsert with variables surrounded by ^ characters to achieve the same effect as the string concatenation.  But they're not the same thing.
I like using evalinsert because it gives a cleaner look to the code, where you need to insert variables into a string.
