BookmarkSubscribe
rahulsmils
Correlating two indicators dependent on same parameter
Hi all,
I am new to jmp. So I am not aware if jmp already have a GUI interface to perform following operation.
Else I will need to script this but I need help understanding most efficient way to do this:
I have 2 data tables:
dt1 has columns: Distance, Temperature
dt2 has columns: Distance, Cost
I want to create a plot of Cost vs. Temperature.
Only parameter common is Distance but Distance in dt1 is not exactly 1:1 same as with dt2 [Both are numeric but differ in values]
So I will need some interpolation.
Please let me know the best way to code this.
Re: Correlating two indicators dependent on same parameter
A similar question was asked recently about joining data by a timestamp, where the timestamps do not match exactly.  I think it might be your solution
Merge data by time stamp
rahulsmils
Thanks, my data set is a bit more complicated.
The script of timestamps breaks for me.
I will give it a more thorough try.
I am not sure of your final purpose. You might have to use a join if you mean to literally plot observations of temperature and cost that share a common or nearly distance. If instead you simply want to explore and examine the relationship between temperature and cost via distance, what about modeling temperature by distance and modeling cost by distance, saving each model as a column formula, then copying these formulas to the same data table or a new one with a distance column. You could plot temperature and cost as Y against distance as X in Graph Builder now. (Graph Builder does a great job with formulas!) You could also plot temperature against cost directly. You might have to play with the number of rows and increments for distance to get the resolution you want in the plotted curve.
