BookmarkSubscribe
keyurkj
Community Member
Copy a row cell and populate into column
Hello everyone,
I am novice with regards to scripting in JMP. I have a following task which I specifically want to use script to solve it. Any help would be appreciated
I am describing my question using the following table
Example 1
NameAndrew1
NoInformationdetailsCol.
1x1
2xx2
3 ....till 10xxx3
In the above example there are 10 entries
I want to select a particukar row ( in this case row 2); concatenate  and populate the last column for the 10 entries as Andrew1, thus the table would look like
Example 1
NameAndrew1
1x1NameAndrew1
2xx2NameAndrew1
3 ....till 10xxx3
NameAndrew1
Thank you
cwillden
Re: Copy a row cell and populate into column
Hi @keyurkj
Can you post an example table with multiple entries?  Based on what I'm seeing, your data is in a very unfriendly format for JMP.  Keep in mind, JMP is not a spreadsheet program like Excel.  On the surface, this feels like trying to coerce JMP to be like Excel.  If that's how the data comes, we can probably do some pre-processing to get the data in a better format.  That's why I'm asking to see a more thorough example.
-- Cameron Willden
