pmroz
Copy Listbox Contents with LF delimiters Instead of Tabs?
If I copy the highlighted contents of a listbox I get a tab-delimited string.  However I want each selected entry to be on its own line.
nw = new window("test",
	lb = list box({"AAAAA", "BBBBB", "CCCCC", "DDDDD"}, width(100),
		max selected(-1),
		nlines(8)
If I highlight the last three entries and right-click copy
I get this string:
BBBBB	CCCCC	DDDDD
What I want is this:
BBBBB
CCCCC
DDDDD
I can create my own "Copy to Clipboard" button that will do the conversion, but is there an easier way?
gzmorgan0
Re: Copy Listbox Contents with LF delimiters Instead of Tabs?
@pmroz ,
Your solution is not so bad, except for management of button box and listbox. However, you could use relative object references: each Copy Button and ListBox are nested in a VListBox Container and for the ButtonBox, use <<Set Function(Function({this}...)) where the listbox can be referenced as  (this << sib) << get selected, etc. A script example called Copy_ButtonBoxSib.jsl is attached.  This is likely not new to you, just here as an FYI to others on the Community Blog.
A ListBox() has an option to <<Set Context Script(). With a context menu script, the copy button is not required.
I have not figured out if there is a method to reference itself in the menu script. Here is a simple script with 3 ListBox with a context menu script to copy:
  • Select items
  • Right click in the ListBox, Copy will appear, select it.
  • I placed a button to paste the text to test this
See the screenshot and script.
Names Default to Here(1);
lf = "\!N";
mylb =Function({usrlist}, {lb},
	lb = ListBox(usrlist, width(100), max selected(-1), nlines(8));
	lb
mycopy = Function({this}, {sel},
	sel = this << get selected;
	if(nitems(sel)>0, set clipboard(concat items(sel,lf)) )
mylist1 = {"AAAAA", "BBBBB", "CCCCC", "DDDDD"};
mylist2 = {"xxxxx", "yyyyy", "zzzzz", "wwwww"};
mylist3 = {"dog", "cat", "parrot", "hamster"};
lb1 = mylb(mylist1);
lb2 = mylb(mylist2);
lb3 = mylb(mylist3);
list_lb = {lb1, b2,lb3};
New Window( "Example",
 VlistBox(
   HListbox(lb1,lb2,lb3),
   ButtonBox("show It", <<SetFunction(Function({this}, {cb},
   	  cb = get clipboard();
   	  (this<<sib) << Set Text(cb);
   TextBox()
//I don't know how to specify "this" for Context Menu Script
//If there is a method, then the context menu script could be assigned
//with the mylb() function
lb1 << Set Context Menu Script( {"Copy", mycopy(lb1)} );
lb2 << Set Context Menu Script( {"Copy", mycopy(lb2)} );
lb3 << Set Context Menu Script( {"Copy", mycopy(lb3)} );
6 REPLIES 6
you might try adding \!n to the end of each value and see if that gives you what you want. It would be a kluge, but it might get the job done
pmroz
Interesting idea Jim, but the resulting listbox shows blanks.  When I highlight rows and hit CTRL-C the pasted results are on separate lines but the tabs are still there.
I have multiple listboxes that people want to copy from; I have a dedicated button at the top of each one that uses this logic:
lf = "
	cb = button box("Copy to Clipboard",
		selected_items = lb << get selected;
		if (nitems(selected_items) > 0,
			set clipboard(concat items(selected_items, lf)),
		max selected(-1),
		nlines(8)
gzmorgan0
@pmroz ,
  • Select items
lf = "\!N";
	lb
 VlistBox(
   TextBox()
pmroz
Thanks @gzmorgan0 that's a really cool technique.  Now I'll have to train my users to right click > Copy instead of using CTRL-C.
vince_faller
You could evaluate the box in the function to send a self referential function.
	Eval(Substitute(
		Expr(DV_LB << Set Context Menu Script({"Copy", mycopy(DV_LB)})),
		Expr(DV_LB), lb
	lb;
*CAVEAT* last I checked this method doesn't work when encrypted.
Vince Faller - Predictum
gzmorgan0
Thank you @vince_faller.  This eliminates the need for a for loop.
The substitute() passes the JMP parser, where assigning the property straight away did not work.  Nice work around.
