bzanos
Copy File Function
I am using JMP 12.
I just want copy five csv files with different name from A folder and save it in B folder.
The A folder contains many csv files.
Using Copy File function (as below), I can only copy one file at a time.
I need to write below script five time to copy all five files
Copy File( "C:\A\data1.csv", "C:\B\data1.csv" );
Copy File( "C:\A\data2.csv", "C:\B\data2.csv" );
Copy File( "C:\A\data3.csv", "C:\B\data3.csv" );
Copy File( "C:\A\data4.csv", "C:\B\data4.csv" );
Copy File( "C:\A\data5.csv", "C:\B\data5.csv" );
Is there a way to copy multiples files using one Copy File function?
or, is there other function/script that I can use to achieve this objective?
Thank you for your help.
pmroz
Re: Copy File Function
for (i = 1, i <= 5, i++,
	file1 = evalinsert("C:\A\data^i^.csv");
	file2 = evalinsert("C:\B\data^i^.csv");
	copy file(file1, file2);
Georg
just another approach using a filelist or copy directory function,
however tested under JMP 15 with Windows, I have no JMP12.
source_dir = "$TEMP\ADIR";
destination_dir = "$TEMP\BDIR";
// Prepare a directory and some files
If( !Directory Exists( source_dir ),
	Create Directory( source_dir )
Save Text File( source_dir || "\afile.txt", "afile content" );
Save Text File( source_dir || "\bfile.txt", "bfile content" );
Save Text File( source_dir || "\cfile.txt", "cfile content" );
// Generate list of files
file_list = Files In Directory( source_dir );
// Prepare destination directory
If( !Directory Exists( destination_dir ),
	Create Directory( destination_dir )
// Copy all files from list
For( i = 1, i <= N Items( file_list ), i++,
	Copy File( source_dir || "\" || file_list[i], destination_dir || "\" || file_list[i] )
// Copy directory
Copy Directory( source_dir, "$HOME", recursive( 1 ) );
// see results
Open( "$TEMP" );
Open( "$HOME" );
Georg
pmroz
Georg
// Copy directory
// see results
Open( "$TEMP" );
Open( "$HOME" );
Georg
bzanos
Thank you.
