djhanson
Copy Directory() example?
Kind of silly, but for whatever reason I cannot seem to get Copy Directory() to work (JMP 11.1.1 following the to/from and even recursive syntax).  Every time I try I get the dreaded zero in the log file.  Maybe I don't understand the exact syntax required.
So can someone else try Copy Directory() and post an example, including copying of all subdirectories and files if possible?
Copy File() works great btw.  Ap that JSL now has these new utility functions:)thx, dj
djhanson
Re: Copy Directory() example?
Ok, nevermind:)
