BookmarkSubscribeRSS Feed
dp30
Jun 23, 2011
Coordinates of vertices for Mixture Designs
I have to make mixture designs using 13-components mixtures with linear constraints. The experimental region is a convex hyperpolyhedron. I believe JMP uses algorithms called "CONVRT" and "CONAEV" to define the vertices and centroids of the hyperpolyhedron. Do you know whether JMP keeps the information about the coordinates of vertices and centroids somewhere ? I would need to get them... Thanks for your help.
