Hi All,
when attempting to open the html code of a webpage i only get the Cookie Consent text rather than the page content.
For example, being in the UK and attempting to open the jmp homepage this is what i get:
Page = open("https://www.jmp.com/");
String( "<html><hea... 2588 total characters ...></html>
" ) assigned.
print (Page);
"<html><head><script type=\!"text/javascript\!">
function callAjax(url, fallbackUrl, callback){
    var xmlhttp = new XMLHttpRequest();
    xmlhttp.onreadystatechange = function(){
        if (xmlhttp.readyState === 4 && xmlhttp.status === 200){
            callback(xmlhttp.responseText);
    xmlhttp.open(\!"GET\!", url, true);
    xmlhttp.timeout = 3000; // time in milliseconds
    xmlhttp.ontimeout = function() {
        console.log(\!"countrycode xhr request timed out\!");
        window.location.replace(fallbackUrl);
    xmlhttp.send();
function findInLocales(locales, cookielocale) {
    var i = 0;
    var found = \!"\!";
    while (i < locales.length && !found) {
        if (locales[i].substring(2) === '_' + cookielocale.toLowerCase()) {
            found = locales[i];
        i++;
    return found;
function geoResetURL(locales) {
    var windowReplacement = window.location.href;
    var regex = /\/[a-zA-Z][a-zA-Z]_[a-zA-Z][a-zA-Z]\//;
    var regextest =  /[a-zA-Z][a-zA-Z]_[a-zA-Z][a-zA-Z]/;
    windowReplacement = windowReplacement.replace('.geo.', '.');
    var match = document.cookie.match(new RegExp('(^| )usr_locale=([^;]+)'));
    var cookielocale = '';
    if (match != null && match.length > 2) {cookielocale = match[2];}
    if (!cookielocale.match(regextest)) {
        var result;
        var code = Math.random().toString(36).substring(2, 15) + Math.random().toString(36).substring(2, 15);
        callAjax( '/services/countrycode?'+code, windowReplacement,
                function (result) {
                    var jsonresult = result.replace(/[()]/g, '');
                    cookielocale = findInLocales(locales, (JSON.parse(jsonresult)).address.country_code);
                    if (locales.indexOf(cookielocale) != -1) {
                        windowReplacement = windowReplacement.replace(regex, '/' + cookielocale + '/');
                  window.location.replace(windowReplacement);
    } else {
(function () {
var locales = ['en_us','en_be','de_at','zh_cn','en_dk','fr_fr','de_de','it_it','ja_jp','ko_kr','en_nl','en_ch','en_gb','en_ca','fr_ca','zh_tw','pt_br','es_mx','es_es','en_au','en_hk','en_my','en_ph','en_in','en_sg','es_ar','es_cl','es_co','es_pe'];
geoResetURL(locales);
  }) ();</script></head><body>
<p>Redirecting ...</p></body></html>
Many thanks for any suggestions in the right direction.
ron
