BookmarkSubscribeRSS Feed
scottdprm
Community Trekker
Jul 1, 2016
Converting numeric text data collected from listbox to a matrix
The list data below (LotSlot_Start) was extracted from a list box in an app I am creating. I am trying to turn it into a matrix with of form [14, 13].  The below gives me what I want, but I want to be able to do it for any number of entries.
LotSlot_Start = {"14", "13"};
//This gives me what I want: slot_start = [14, 13]
Slot_Start=Matrix(num(lotslot_start[1]));
Slot_Start=v concat(slot_start,Matrix(num(lotslot_start[2])));
show(Slot_Start);
I have created this script:
//This crashes jmp and I can't figure out why
for(i=1, i=nitems(lotslot_start), i++,
	If(i==1, Slot_Start=Matrix(num(lotslot_start[i])));
	If(i>1, Slot_Start=v concat(slot_start,Matrix(num(lotslot_start[i]))));
show(Slot_Start);
But it always crashes JMP when I try to run it.  I can't figure out why.  Any help would be appreciated.
Thanks,
ih
Community Trekker
Sep 30, 2016
Solution
Re: Converting numeric text data collected from listbox to a matrix
That is what I get for getting distracted before hitting send.  Glad you figured it out..
scottdprm
Community Trekker
Jul 1, 2016
Nevermind I figured out what the issue was I forgot the '<' when defining the range of i, 'i<=nitems()'
ih
Community Trekker
Sep 30, 2016
The second argument of the for loop needs to less than or equal to, right now it is false for the first value of i.
for(i=1, i<=nitems(lotslot_start), i++,
ih
Community Trekker
Sep 30, 2016
Solution
