BookmarkSubscribeRSS Feed
ron_horne
Jun 23, 2011
Controlling the extent of a map while animating
Hi all,
I was wondering if it is possible to determine and maintain a fixed extent to a map while animating. After running the following script, if you press the Play button you can see that for each Storm Category the background maps’ position changes. I would like to keep the background map constant while the animation goes ahead.
Thanks!
dt = Open( "$SAMPLE_DATA/Hurricanes.jmp" );
New Window( "Map",
     Graph Builder(
          Auto Stretching( 0 ),
          Variables( X( :Longitude ), Y( :Latitude ) ),
          Elements( Contour( X, Y, Legend( 5 ), Number of Levels( 0 ) ) ),
          Local Data Filter(
              Location( {290, 21} ),
              Add Filter(
                   columns( :Storm Category ),
                   Where( :Storm Category == "TD" ),
                   Display( :Storm Category, Size( 204, 264 ), List Display )
              Mode( Select( 0 ), Show( 1 ), Include( 1 ) ),
              Animation( Animate Column( :Storm Category ) )
              Dispatch(
                   "Graph Builder",
                   FrameBox,
                   {Background Map( Images( "Simple Earth" ) ), Grid Line Order( 2 ), Reference Line Order( 3 )}
Jun 22, 2012
Solution
Re: Controlling the extent of a map while animating
In the script that you provided in your question, does not define the axes, so the Graph Builder platform is left on it's own to define the axes.  All I did, was to run your script, go to the graph and change bot the x and y axes very slightly, and then copy the new script into the script window.  The new script now holds the axes from display to display.
Graph Builder(
       Fit to Window( "Off" ),
       Elements( Contour( X, Y, Legend( 5 ) ) ),
       Local Data Filter(
              Add Filter(
                     Display( :Storm Category, Size( 208, 259 ), List Display )
              Dispatch(
                     "Longitude",
                     ScaleBox,
                     {Min( -121.705030849549 ), Max( 3.22722958105018 ), Inc( 20 ),
                     Minor Ticks( 0 ) }
              Dispatch(
                     "Latitude",
                     ScaleBox,
                     {Min( -25.3559216730956 ), Max( 78.1820193180142 ), Inc( 25 ),
                     Minor Ticks( 0 )}
              Dispatch(
                     "Graph Builder",
                     FrameBox,
Jun 22, 2012
Solution
Graph Builder(
       Local Data Filter(
              Add Filter(
              Dispatch(
                     "Longitude",
                     ScaleBox,
                     Minor Ticks( 0 ) }
              Dispatch(
                     "Latitude",
                     ScaleBox,
                     Minor Ticks( 0 )}
              Dispatch(
                     "Graph Builder",
                     FrameBox,
ron_horne
Jun 23, 2011
thank you jim,
this does the trick perfectly.
pmroz
Jun 23, 2011
There's another way that might be easier.  Right click on the graph builder red triangle and select Lock Scales.
New Window( "Map",
     Graph Builder(
              Show Control Panel( 0 ),
          Lock Scales( 1 ),
