sczupryna0
Control charts
Does anyone know how to create an X-bar/R control chart when only the subgroup mean and range is available, rather than the entire data set?
Steve Czupryna
Samson Rope
cwillden
Re: Control charts
You can plot each of those columns on individuals charts and hard-code the limits as column properties.  Here's an example using Control Chart Builder.
-- Cameron Willden
cwillden
Re: Control charts
-- Cameron Willden
sczupryna0
Re: Control charts
Thanks for the (lightning fast) answer.  I understand your method and it'll work great for my application.
Steve
