BookmarkSubscribe
philip_kotliyak
Community Member
Control chart as script in button box
Hey, im using JMP 9.0.3
Im trying to write script to make macro to generate control charts and save them to the file.
I encountered this error and i have no idea how to solve it, i looked for couple hours for solution and nothing seems to work.
the code is :
clear globals();
jrn=NewWindow("SPC Analysis "|| Format(today(),"yyyy-mm-dd"),VListBox(
        button box ("Choose JMP Data File",Data_Table=open(Pick File(),invisible);),
        global box(Data_Table),
        button box ("Choose Specification JMP File",Spec_Table=open(Pick File(),private);
        for (i=2,i<=Ncol(Spec_Table),i++,
        eval (
        eval expr(
        column(Data_Table,i+1)<<Set Property("Spec Limits",{        LSL(expr(column(Spec_Table,i)[1])),
        TARGET(expr(column(Spec_Table,i)[2])),
        USL(expr(column(Spec_Table,i)[3])) })
        global box(Spec_Table),
        button box ("Run XBar Control Chart",cc=
        Control Chart (
        Sample Label ( :column(1) ),
        KSigma( 3 ),
        Chart Col( : column(Data_Table,3) ,XBar,S)
close all(Data Tables,no save);
the error is at the red part, if i just run the control chart function, it works, if as sript inside button box, it doesnt.
Thanks.
pmroz
Re: Control chart as script in button box
You have a non-modal dialog box, which means that everything gets executed, including the closeall at the end.  I would add a Close button to your dialog box that executes the closeall instead of how you're doing it.
Clear Globals();
jrn = New Window( "SPC Analysis " || Format( Today(), "yyyy-mm-dd" ),
    V List Box(
        Button Box( "Choose JMP Data File",
            Data_Table = Open( Pick File(), invisible )
            Global Box( Data_Table ),
            Button Box( "Choose Specification JMP File",
            Spec_Table = Open( Pick File(), private );
            For( i = 2, i <= N Col( Spec_Table ), i++,
                Eval(Eval Expr(
                    Column( Data_Table, i + 1 ) << Set Property("Spec Limits",
                            {LSL( Expr( Column( Spec_Table, i )[1] ) ),
                            TARGET( Expr( Column( Spec_Table, i )[2] ) ),
                            USL( Expr( Column( Spec_Table, i )[3] ) )}
            Global Box( Spec_Table ),
            Button Box( "Run XBar Control Chart",
            cc = Control Chart(
                Sample Label( :column( 1 ) ),
                KSigma( 3 ),
                Chart Col( :column( Data_Table, 3 ), XBar, S )
            button box("Close", Close All( Data Tables, no save );
                    jrn << close window;
