atlas100
Control Chart Builder, Show Limit Summaries Bug?
I want to turn off the limit summaries when using Control Chart Builder using a script. When I use the following command in my script.
Show Limit Summaries( 0 );
It only hides the limit summaries for the first control chart, the other variables being tracked have their limit summaries showing. When I use the little red triangle drop-down in the control chart window, selecting "show limit summaries" turns them off for all variables tracked.
atlas100
Re: Control Chart Builder, Show Limit Summaries Bug?
I fixed this condition by placing the Show Limit Summaries at the end of the script.
atlas100
