BookmarkSubscribeRSS Feed
sidewinder
Jun 23, 2011
Contour plot from two models
Hi!
I have two outputs from a DOE, each with its own model. If someone could point me in the direction of how to mix two models into a contour plot, I would really appreciate the help! Thanks.
sidewinder
Jun 23, 2011
Re: Contour plot from two models
Okay, I made some progress! When you have two contour plots open, you can LINK them! Right click on the Contour Profiler-->Factor Settings-->Link Profilers and then the two contours are set up to follow each other.
louv
Jun 23, 2011
Once you have your desired model go to save columns > prediction formula for each response. Then go to Graph > Contour Profiler and add all of the prediction formula's to the Y, Prediction formula box. Then click ok and both or all of your responses will be plotted on one contour plot.
Message was edited by: Lou V@JMP
sidewinder
Jun 23, 2011
That looks AWESOME! F'n great weekend to you, amigo! Sweet.
