BookmarkSubscribeRSS Feed
jsuls
Jul 30, 2014
Contour Plot with VB Automation
Hey, I am trying to create a contour plot from a data table using VB automation. I need to specify to "Fill Areas" and set the maximum and minimum contour levels. Thanks
Here is what I have so far. I keep getting a runtime error 438 for the line "Set con = jmpdoc1.CreateContour"
Sub JMP()
    Dim jmpdoc1 As JMP.Document
    Dim myJMP As JMP.Application
    Dim DT As JMP.DataTable
    Set myJMP = CreateObject("jmp.application")
    myJMP.Visible = True
    Set jmpdoc1 = myJMP.OpenDocument("C:\Users\jsuls\Desktop\test.csv")
    Set DT = jmpdoc1.GetDataTable
Dim con As JMP.Contour
            con.LaunchAddY ("Z")
            con.LaunchAddX ("X")
            con.LaunchAddX ("Y")
            con.FillAreas (True)
            con.SpecifyContours(5.0,20.0,6.0,True)
            con.Launch
End Sub
briancorcoran
Jun 23, 2011
Solution
Re: Contour Plot with VB Automation
Sorry, for some reason I didn't get a notification of a reply.  The call in Automation to create a Contour Plot is CreateContourPlot, not CreateContour.  Do you have CreateContourPlot?
briancorcoran
Jun 23, 2011
For text files, you must use the text import interface to automation.  The Text Import sample application in your Samples Automation folder gives an example.  For JMP 11, the location would be something like C:\Program Files\SAS\JMP\11\Samples\Automation\Visual Basic Samples\Text Import .NET.
If you open that example, you will see that a typical sequence to open a CSV file would be something like:
        Dim TI As JMP.TextImport
        TI = MyJMP.CreateTextImportObject("c:\program files\sas\jmp\11\samples\import data\Book1.csv", 10000)
        TI.SetEndOfFieldOptions(JMP.jmpTIEndOfFieldConstants.tiComma)
        TI.SetEndOfLineOptions(JMP.jmpTIEndOfLineConstants.tiCRLF)
        TI.FirstLineIsData(True)
        Doc = TI.OpenFile()
jsuls
Jul 30, 2014
The problem isn't opening the csv file. I can open it with the code above. The problem is generating the contour plot. I can create distributions, surface plots, etc. using this vb code. The only problem that occurs is when I try to create a contour plot. I keep getting the "object doesn't support this property or method" error message
briancorcoran
Jun 23, 2011
Solution
