BookmarkSubscribeRSS Feed
KarenC
Feb 10, 2013
Consumer Research - Missing Selections
How do I add a category that no one selected so I can get the zero counts in the category platform?  I tried to add it in the value ordering and in the list check to no avail.
michael_jmp
Jun 23, 2011
Solution
Re: Consumer Research - Missing Selections
Hi Karen,
Sorry you weren't able to find the right option for this. The option "Include Responses Not in Data" is a checkbox on the launch window as well as available as a option in the red triangle menu under "Category Options". You had the right idea, though, to use a column property. You will need to use Value Labels to specify the level that has zero counts.
Here is the documentation for Category Options:
Example of the Categorical Platform
Hope that helps,
Michael
Michael Crotty
Sr Statistical Writer
JMP Development
michael_jmp
Jun 23, 2011
Solution
Hi Karen,
Hope that helps,
Michael
Michael Crotty
JMP Development
KarenC
Feb 10, 2013
Thanks Michael,
Value labels was my next thought but I didn't feel like setting them up (lazy analyst).  I would suggest strengthening the wording in the manual to something along the lines of "the use of missing categories requires the use of value labels".
Karen
michael_jmp
Jun 23, 2011
Thanks for the suggestion!
Michael
Michael Crotty
JMP Development
