wu
wu
Connected to Postgre database connection, however not seen table scripts
The tables scripts used appear on the top  left side corner, after making the connection to data base,
and opening  any one of table list  under the box of Schemas -Tables with following scripts.
"Source"
"Update From DB"
"Save To DB"
Since last week, those scripts disappeared, only the table itself.
Any clue?
Re: Connected to Postgre database connection, however not seen table scripts
There is a Preference called "ODBC Hide Connection String" under the Tables preferences.  If you selected this option, those scripts will no longer appear because they contain the connection information.
Brian Corcoran
JMP Development
