Confidence interval for Odd Ratio in nominal logistic regression
In JMP 5.0, I was able to obtain confidence interval for odd ratios in nominal logistic models in the Fit Model Platform. In JMP 8.0, I could get the odd ratios but I could not get the confidence interval. Do I have to hand-calculate these intervals or can that be done in JMP 8.0?
Paul
Re: Confidence interval for Odd Ratio in nominal logistic regression
Just an update: I asked technical support, and they told me that feature was taken away in JMP 8.0. They received a lot of requests and they will program this feature back into future JMP revision.
