adam
Conditional Formatting If and print result
I am setting up few criterias for a Pass/Fail result with IF AND statement as shown below:
If( :Criteria 1 == 0 & (:Criteria 2 == 0 & (:Criteria 3 == 0 & :Criteria 4 == 0)),
0,
1
For the result, it return as either 0 or 1. I would like to know is it possible to change it to Pass or Fail instead of just 0 or 1.
Thanks.
ian_jmp
Re: Conditional Formatting If and print result
Looks like you are using a formula to define a new (Numeric) column. In which case you can use an appropriate value label to recast the appearance of the values. Else you could use a Character column and have values as "Pass" and "Fail" strings.
uday_guntupalli
Level VIII
dt << New Column("Result",Character,Continuous,Formula(If( :Criteria 1 == 0 & (:Criteria 2 == 0 & (:Criteria 3 == 0 & :Criteria 4 == 0)),
	"Fail",
	"Pass"
Try this . I think Ian is referring to this ..
Best
Uday
ian_jmp
uday_guntupalli
Level VIII
	"Fail",
	"Pass"
Best
Uday
adam
Thank you very much Ian and Uday. It works as expected :)
