eliyahu100
Concatenate tables columns with labels
I an trying to concatenate two tables with identical column names/
The thing is some of the columns have labels that are base on different values, since they came from two different sources.
for instance in one table Value Labels({1 = "Yes", 2 = "No"})
and for the second Value Labels({1 = "Yes", 0 = "No"})
so when concatenating i get two seperate No valuse, namely No:0 and No:2 as you could see in the following analysis.eliyahu100_0-1594297856201.png
Any suggestion how to force JMP to treat No as No?
TIA
Re: Concatenate tables columns with labels
You will need to Recode one of the tables to matching values before concatenating them.
You can find the details of how to use Recode in the JMP documentation here: https://www.jmp.com/support/help/en/15.1/index.shtml#page/jmp/recode-data.shtml
